I just took a look at the directions for EMG J system
(h
ttps://www.emgpickups.com/pub/media/Mageants/j/_/j_system_01_08_2016ra.pdf)
It looks like they think the battery may fit under the control plate. If that's true you wouldn't need to make a separate cavity for the battry. You'd just need to remove the 3 screws when you want to change the battery. You could attach a clip to keep the battery from sliding around, or you could just wrap it in some thin EPS foam or something.
Whether the battery fits depends a bit on your control cavity. If it doesn't, you could widen or deepen the cavity a little to make the battery fit. You can do this with a chisle, a router or a rotary tool. The router will make the cleanest cut, but that may not matter so much since it will be out of sight ;-)
If you are interested in adding a battery box, it would not be to hard to do, but there is no reason you couldn't add it later as well, and it may be with this system you won't need to do frequent battery swaps. I read that the preamp is built into the pickups. That probably means that your tone control is passive, so it won't be drawing power. You'll want to make sure that you unplug your cable any time you are not playing the bass, since it functions as an on-off switch for the preamp. I learned that the hardway, resulting in a number of unnecessary battery swaps...
If you are thinking about putting in a battery box I would put it about here on the back of the bass:
Same answer as before about what you'll need to do it, but a router is best, I think. If you don't have a router you can do it with a chisle or rotary tool. If you use a box like this the lip around the edge will hide small imperfections:
