How to setup a 9v battery enclosure & associated wiring for the JB4 bass kit
dalpets
New member
I would like to transform this kit from passive to active & ,if possible, would like fairly comprehensive details for a 9v approach that avoids ruining the kit. I am generally able to follow technical stuff but I am a complete novice in this area. Additional tips would also be especially helpful particularily positioning of the enclosure.
Thank you
I know nothing on this topic!
A few members have installed active pickups and added room for the 9V battery - I will have a bit of a search to see if I can find them.
Hopefully others will have ideas.
There is more than one way to do it, but my recommendation would be to add a battery box that can be accessed from the back of the bass. That will save you unscrewing the pickguard or control plate every time you need to change the battery.
Here are a couple of pics of how I did it on my G&L ASAT:
It's not all that difficult if you use a router and a template. You just need to find a spot that isn't being used. Most people put theirs where mine is or near the bridge.
You'll also need a box... I like the wide ones because it makes battery swaps easier:
I made a very simple router template that I clamped to the back of the bass:
If you are using a set EMG J's that's pretty much all you need to do. If you are using pickups that have a separate pre-amp, like Aguilars, you may need to route a space under the pickguard for that. You can use the same template for both. I have kept my template, which I made to fit the battery box exactly... but since I am lazy I have also learned that I can make a bigger hole pretty easly by cutting one part with this template and then moving it to make the hole bigger ;-)
Thank you
This youtube video
provides a detailed EMG approach for a passive to active installation. In this case the 9v battery is included within the electronic control panel cavity, not separately. I think this construction method is superior because of it relative simplicity but the cost of the kit is rather daunting.
He left a couple of critical things out of the video IMHO. One is exactly where he put the battery. I don't think it's under the control plate--you can see pretty clearly that there would not be room. I guess it's possible that his Squire has room under the pickguard for it on his bass. But YMMV ;-) In other words, if you want to go that route (no pun intended) you may want to check to see if there is enough room for the pickup and the battery under the pickguard. If it's like other JB-4s...
...it doesn't look like there's much room in there. So, you would need to rout or carve out some space for the battery. It wouldn't matter what it looks like because it would be under the pickguard, so that's an advantage over the battery box. The bad news is that you'd need to remove 10 screws every time you need to change the battery. You'd also need a clip like this...
...to keep the battery from sliding around.
My G&L had a place for the battery under the cavity cover, but I got tired of taking the screws out every time the battery needed changing even though there were only six. I had to do it at a gig once, and it was embarassing how long it took. The other thing is that I decided I didn't want a battery so close to the electronics in case I forgot about it and it began to leak.* Aside from convenience, the box keeps any leakage isolated from the rest of the electronics.
*I put switches where the old battery cavity was eventually, but that was an afterthought once I had decided to add the battery box for convenience and to isolate the battery in case of leakage.
Back
Top
