Results 1 to 10 of 40
Thread: Reworking an Explorer Semi scratch
    About 30 years ago I picked up a Cimar strat type guitar quite cheap second hand as my second (bash around) guitar. It had a nice neck, played quite well and the humbucker PUP sounded good. My aim was to do a semi-scratch build and replace the body with an explorer shape. I copied the explorer shape from a Guitar World magazine advertisement. Joined a few pieces of pine wood together and eventually I had a guitar that was loved and played a lot. All the routing was done by hand, the finish was very poor, it was a bit mistreated. I did learn a lot about carpentry, soldering, string setup etc.
    I have decided to pull her apart and clean her up. I cannot fix all the things wrong but I can at least try.
    Shots before being pulled apart:
ID:	37590   Click image for larger version.
    I must say that looks pretty good as is.
    Cheers, Waz
    Thanks Waz,
    but it never passed a 3 foot rule, or 3 metre rule etc.
    And it gives me a project while the other builds are waiting for parts to arrive in the mail.
    Mentor blinddrew's Avatar
    Apr 2018
    York, Uk
    And that's what's really important!
    Going to leave it natural or stain or paint it?
    Cimar were a fairly short-lived branch of Ibanez (about '75-'82) and shared headstock design and a lot of the body shapes and hardware.
    Hi Simon,
    I will leave it natural. I will coat it with tru-oil.
    I sanded the body back today and filled the knot holes with CA glue.
    I still have to cover some unmatched dowel to blend it with the pine. I'm not sure if I should use putty or get a wood plug cutter!
    More sanding and I also routed the face and back edges with 1/4 round bit.
    I couldn't cover the dowels nicely so I'm embracing them. I darkened them to create a contrast.
    Also given 3 coats of tru-oil.
    I like it!
    I'm going to do a pine tele scratch build one day.
    Looks great and will look even better once the Tru Oil ages.
    Thanks McCreed and wazkelly.
    I'm a lot happier with the finish already. I will give it quite a few more coats of tru-oil though and it should darken a bit more.
    Regards
