Bass cabinet build: Pair of Jack 12 Lites
fender3x
Moderator
Staff member
Some years ago I built what I thought would be sort of the ultimate in bass cabs. I used designs created by Bill Fitzmaurice. My main all purpose cab has been one of his DR250 cabs. This is a folded horn design that has size and output similar to a typical 4-10 cab, but is considerably lighter. Mine weighs in at around 20 kg. For playing outdoors, I have typically added one of his Titan 39 subwoofers. It's not much heavier than the DR250, but is overkill for most situations, and while it has wheels, it's akward to carry.
Lately I have been thinking that the DR250 is overkill for practice situations, and that I might maximize my flexibility if I had a pair of 1-12 cabs. I could use just one for typical pactice room situations, and two for most gigging situations. Also Bill Fitzmaurice has designed his "Jack Lite" series to be pretty much the lightest, high output cabs available. They are also just enough smaller than my current cabs to be easier to pack in my small pickup (aka compact ute?)
So, I bought the plans, got the plywood, and have decided to move this project up to front burner...as time allows. Finished product, without tweeters should look something like this:
Mine will have tweeter arrays in the front so that they could be used as PA cabs in a pinch, although with my current setup, I generally turn the tweeters off.
Figured I'll post progress on this project here when I have some. In the meantime, if you are interested in these designs you can find out more about them here:
https://billfitzmaurice.info/
This will be my fourth build of one of his Bill's designs. I especially love the DR250 which is a great all purpose cab. It's not all that heavy for a bass cab, but I'd like to have something even lighter. My DR250s are light for bass cabs at about 20kg, but a Jack Lite should weigh in around 9kg, and I think my back will like that better ;-)
Back
Top
