Results 1 to 10 of 18
Thread: OK. Help. Stain bleed.
    Hello All
    I'm sure I'm not the first and won't be the last. I taped the trimming or binding or whatever you call but the stain still leaked into it. See photos. Can this be saved or will I just go over it with the stain anyway and make the best of a bad job?
    Brad
Name:	Stain Leak Guitar Side.jpg
ID:	31493   Click image for larger version.
Name:	Guitar Body Side.jpg
ID:	31494   Click image for larger version.
Name:	Taped Side Cropped.jpg
    Moderator Brendan's Avatar
    Apr 2013
    Should be pretty straightforward to fix. If you get a razor blade flush with the binding and gently scrape, you should be able to get rid of it. They use a special tool, but you can just as easily use a razor blade or box cutter blade... Just watch the fingers
    Apr 2013
    Sorry @Bradboy - just tagging you in for an answer.
    Member Joe3334's Avatar
    Aug 2017
    Warrnambool
    Some people have used methylated spirits to remove excess stain that has bled through into binding.
    Thanks all. I'll give those a try. I really want to salvage the binding cos it looks really good against the walnut.
    Thanks again.
    Bradboy
    That looks really good. I'll definitely give this method a shot. It's almost not worth taping the binding at all.
    Thanks again.
    Bradboy
    Mentor
    Aug 2018
    Perth, Australia
    I wrap tape around the razer blade to create a depth stop.
    Sort of like this except I don't use this much tape. (Part way down the page)
    https://www.mylespaul.com/threads/i-...802697&slide=0
    Sent from my SM-G960F using Tapatalk
    Quote Originally Posted by Woltz View Post
    Same, It's not as scary as it looks, some tape round the blade and fingers firmly against the body it's pretty straight forward.
    Good luck.
    #1 LP1-SS
    #3 TL1 - Custom
    #5 RC4
    #6 STA-1HT
    #7 Non PB 52 Tele replica
  9. Liked by: dave.king1
    Yeah, that's a great idea. I did a bit of experimenting this morning. Got the hang of it. Off to buy some razors.
    Thanks again.
    Bradboy
    Sorry, I this reply was for you:
    "Yeah, that's a great idea. I did a bit of experimenting this morning. Got the hang of it. Off to buy some razors.
    Thanks again.
    Bradboy"
