Results 1 to 10 of 20
Thread: Made a start!
    Made a start!
    Did my dry run on Sunday and all looked good.
    I took a saw to my headstock and also repaired a ding in the bottom of the neck. Spent the rest of the day sanding and am now getting close to adding some stain.
ID:	25439   Click image for larger version.
    Cool
    Spent last weekend sanding & sanding. Turned out it still wasn't enough!
    This weekend I started adding some colour, the pics are early on, it's looking better now. I used UBeaut water based stain for the front & back & Feast Watson jarrah for the sides & neck. The water based dye is very forgiving but it does raise the grain a bit. I found it wasn't a good idea to follow the instructions to wet the surface first, it pulled the grain too much. It worked much better to add the dye to a dry surface in sparing amounts & really work it in.
    I was a bit disappointed when I first added some colour to the neck, the 2 different types of wood either side of the skarfe joint absorbed dye at wildly differing rates making the joint really obvious. I always intended going really dark so after a few more coats it doesn't look so bad now.
    I'll leave the dye to dry for a few days now before glueing the neck to the body. I'm thinking of using tung oil for the final finish, i've used it on some cigar box project & liked it. Has anyone else used it?
ID:	25540   Click image for larger version.
    Started with some oil. Decided on Tru Oil in the end. 3 coats so far, several more to go but I think i'll try a light sand with some 1500 wet & dry before the 4th coat.
ID:	25570   Click image for larger version.
ID:	25571   Click image for larger version.
    Great contrast. Nice looking all over.
    Yeah I have also found it difficult to keep things even doing a stain. Putting a clear on really does change things though and it ends up looking fine.
    i've had this kit a few weeks now and only just realised that the body has a hole for a 3 way switch & a 3 way switch was included in the kit but, as a ES175 copy, the guitar has only a single pickup. Surely the switch shouldn't be there but i'm going to have to include it to fill the hole. Any ideas?
    The switch hole obviously shouldn't be there. What pickup do you plan to install? You've got a humbucker-sized mounting hole. To make use of the switch hole, you could install something like a Seymour Duncan P-rails, and fit a suitable selector switch in the hole (not the supplied 3-way switch) for Humbucker, P-90 and single coil sound selection.
    https://www.seymourduncan.com/wiring...tions,1-pickup
    Alternatively, you could fill in the hole, spray a dark opaque sunburst over the top (similar to the picture) and hide the repaired hole under the finish. You'll need to try and find a spray that is compatible with the Tru-Oil you've already applied, so try out on some test wood first.
    Maybe add in a push/pull switch to coil split a humbucker or to do series/parallel?
    Hi Simon,
    Thanks for the advice, I wasn't aware of the P-Rails. I've had a look at the SDuncan videos & it looks like I would need a 4 way switch for a single PRail so i'm guessing some sort of rotary switch.
    It would the guitar an individual. I had planned to go bog standard on my first build but what the heck!
    No, it's an on-off-on 3-way. Sorry, I didn't check the link and it didn't show the wiring diagram for a single P-rails. Here it is. https://docs.google.com/gview?embedd...ail_3mt_1V.pdf
    Perfect, thanks.
