Results 1 to 10 of 56
Thread: Korean PRS Kit
    Mentor vh2580's Avatar
    Cleveland Qld
    Korean PRS Kit
    Started work on the Korean PRS kit that posted previously in the Korean Kits thread.
    Couple of photos of the body,headstock and a quick mock build.
ID:	22915   Click image for larger version.
ID:	22916   Click image for larger version.
ID:	22917   Click image for larger version.
ID:	22918   Click image for larger version.
Name:	mock build.jpg
    Tony
  2. Liked by: Swanny
    Jun 2017
    North East UK
    Looks good, I didnt realise that the tuner holes were not drilled in them, that is some size paddle to play with...
    Cleveland Qld
    So started on the neck and decided to go the full PRS with rosewood headstock plate. Found an outline on the Web and did a rough workout of tuner positions trying to get as close to straight strings to tuner as possible. The kit came with tulip style tuners that didnt quite suit so using a set of Gotohs instead. Once cut to shape and holes drilled, sanded off the maple veneer and thinned the headstock down a touch so that wouldnt be too thick once headplate attached. Cut headplate to roughly the shape.
ID:	22920   Click image for larger version.
ID:	22921   Click image for larger version.
ID:	22922   Click image for larger version.
ID:	22923   Click image for larger version.
    Tony
  5. Liked by: Swanny
  6. #4
    Cleveland Qld
    And clamp overkill to make sure is glued well.
    At this stage not 100% sure what colour to stain the body.
    Will use the bridge and tailpiece that came with the kit so colour will need to match chrome hardware.
    Tony
  7. Liked by: wazkelly
  8. #5
  9. #6
    Cleveland Qld
    Simon hadnt thought too but will have a look once I see how well the plate looks once unclamped
    Tony
  10. #7
    Cleveland Qld
    Had a chance to finally do some work on guitars and shaped and drilled holes in Headstock. Added a J-manesque/Nebular chamfer to the back of the headstock.
    As for the body the wishful thinking is to achieve something similar to the pictured PRS.
ID:	23994   Click image for larger version.
ID:	23995   Click image for larger version.
    Tony
  11. #8
    Mentor jarrod's Avatar
    Nov 2013
    Ooo Tony very nice !
    Love the chamfer on the back of the head stock. What a wonderful feature lol......
  12. Liked by: vh2580
  13. #9
    Cleveland Qld
    The one good thing about these solid top kits is that if the colour doesn't turn out as planned you can safely sand back as the first photo. Have the base colour down and once dry will "sand" with 0000 wool to take the colour of the top a bit then repeat.
ID:	23997   Click image for larger version.
    Tony
  14. #10
    Cleveland Qld
    Rubbed back first attempt, hard to get consistent. Second photo with alcohol rubbed in.
    Will repeat to darken the flame a bit and wool again.
ID:	23999   Click image for larger version.
    Tony
