Results 1 to 10 of 28
Thread: Fretworn’s GTH-1
    Fretworn’s GTH-1
    This build is a combination of doing my bit for the economy, a birthday present to myself, rewarding myself for getting to the end of another semester of study and having something to do in lockdown now I’m finished study for the year.
    Still working out the details, but now I’ve got it in my possession I can start to work out what I’m going to do. It’s got black hardware, because Adam’s waiting to be resupplied, and with the black pick guard and some black Toneriders, I’m leaning towards a traditional “blackguard” yellow for the body. But I might change my mind still.
    My son got a GHQ-1 kits as well, so well be building together. If he doesn’t want to do his own build diary, I’ll put on up for his build too.
ID:	34958   Click image for larger version.
ID:	34959   Click image for larger version.
ID:	34960   Click image for larger version.
  2. Liked by: NatetheSoundMan
    That one screams potential, nice score Fretty!
    Wet Saturday afternoon. Perfect time to get started on the woodwork....
ID:	35267   Click image for larger version.
    Nice. Is it a normal tele style bridge on these?
    Given your start point a triple black color scheme seems a no brainer .
  7. Liked by: Simon_B
  8. #6
    A got a little bit done this afternoon. Scale length was pretty much spot on with this kit. Neck connection, bridge positioning sorted and I had to bore out the string ferrule holes to suit the one that I bought for it.
ID:	35390   Click image for larger version.
  9. #7
    Mentor phrozin's Avatar
    Adelaide South Australia
    That's some lovely grain in that body, would look great in yellow dye I've done a couple of yellow Tele's and Strat's the yellow rit dye works really well on them and it's easy to do would be nice with that grain
    Here one with yellow RIT dye with lacquer clear over it
    https://i.imgur.com/FJj2uFk.jpg
    My facebook
  10. #8
    Been a while on this, a combination of forgetting to post progress, general busyness and less hours of sunlight to use......
    Headstock is shaped and I’ve spent a fair bit of time trying to sand the machine marks from the end grain. Eventually discovered the end grain was at 45 degrees to the top, I’ve only had end grain perpendicular or parallel with the top. Some of you will probably look at the photo and go “der” of course it’s 45 degrees, but I was taking for granted that it was perpendicular. Once you find the direction of the grain it becomes a lot easier.....
ID:	36092   Click image for larger version.
ID:	36093   Click image for larger version.
  11. #9
    Love that endgrain fretty.
    Yes you need to sand it "with a vigorous circular motion hitherto unknown to the people of this area, but destined to take the place of the mudshark in your mythology, here it goes now, the circular motion: rub It!"
