Results 1 to 5 of 5
Thread: post conecting top and bottom
    dear all,
    just received my ES 5V guitar kit.
    why if it is made out of ply, supposedly stronger than timber, does it still need a heavy post under the bridge connecting top and bottom?
    thank you.
    Rafael
    Not sure on that one Rafael. I've never looked inside mine. Maybe an easier/ more economic structure for the factory?
    Overlord of Music FrankenWashie's Avatar
    Possibly a sound post? To help transfer vibration to the back and boost volume?
    FrankenLab Guitar Experiments.
    Making bad ideas a reality since 2016!
    Mentor Zandit75's Avatar
    May 2016
    Penguin, Tasmania
    More than likely it is a mixture of many reasons.
    As Andrew mentioned, it would definitely be a cheaper alternative to bracing like found in an acoustic guitar.
    Since the originals, and many high end ones made now, were carved out of solid timbers for the top and back, there would be more built in rigidity using a solid top, than using a pressed into form ply top. I don't know if the carved hollow bodies also have a large central block in them, so I'm only guessing.
    You also need a solid structure to support the bridge. Sure, yours has a trapeze for it, but there is still alot of downwards pressure on the bridge thanks to the strings, and that needs support underneath it.
    Acoustics:
    Electrics:
    Builds in Progress:
    Didn't someone have an issue once with the bass strings pulling out the bridge posts on their semi-hollow build?
